 VW Beetle & Type 2 parts for sale.
steveandcaroline
Cars : 1971 Volkswagen Type 2, 1970 Karmann Ghia, 1988 Porsche 944, 1986 Siera RS Cosworth and 1985 Rolls Royce
Occupation : Engineer for Cummins Power Generation
PostSubject: VW Beetle & Type 2 parts for sale.   Sat Dec 31, 2011 2:39 am
Hi, going to try and have a bit of a clear out for the new year to keep the Girlfriend happy and have the following for sale in Ramsgate if anyone needs any of it.
Beetle ball joint front beam complete with stub axles and drum brakes. Needs a couple of ball joints as the rubbers are persihed and the brakes would need going through as been of a car for about 4 years but a good solid beam. Looking for £60
Beetle steering box. Again been of a car for about 4 years but was all good before the beam was removed and stored undercover outside. Looking for £20 for it.
Beetle disk set up for ball joint beams. Again unused for 4 years so would need going through but all the parts included, disks, calipers and stub axles. Ideal to convert you drum brakes to disc, Loking for £25 for the set.
Beetle track control arms (is that what they are called?) and stering damper. Again unuesd for 4 years but what can go wrong with them? Looking for £5.
Beetle roof rack. Steel tube with wood slats. I think i have a photo of this i will try and upload shortly but basically good condition but if you were fussy you may want to re paint/stain/varnih the wood. Looking for £40 for it.
Set of 4 x 15" OZ alloy wheels and tyres for a Mercedes of some description. I have had them on my Bay window (although ideally you should use different nuts) and will also fit a T25. Tyres are all legal although not the best and one will require a new valve as it leaks. Looking for £40 for the set.
Set of 4 x 16" mercedes alloys. Originally off an A class so would need the bolt holes drilling out to use on a bay or T25 (for some reason the A class uses M12 studs rather than the normal 14mm?) Anyway 3 off really good tyres and one that needs replacing (good tread but damaged side wall) and wheel rims would idealy benefit a refurb. Looking for £70 the set.
Not back in Thanet till the 3rd January but happy to hold things if people want things that badly.
THanks
steveandcaroline
PostSubject: Re: VW Beetle & Type 2 parts for sale.   Sat Dec 31, 2011 2:51 am
Photo of 15" OZ wheels.....i might even give them a wash if someone wants them.
Thanet Classics :: For Sale-
